Does anyone have a definitive command tree structure of CCS trace commands for the SX2000 please?
Cheers, Lee
Cheers, Lee
The two primary commands you will use are CCS TR EN CO (CCS Trace Enable Continuous) CCS TR D (CCS Trace Disable)
The entire CCS command set: (use at your own risk)
CCS RESET DASS2 (Example CCS RESET DASS2) CCS RESET DPNSS ROUTE_OPT_STATISTICS CCS SHOW DASS2 FEATURE_STATUS CCS SHOW DASS2 ROUTE_OPT_STATISTICS CCS SHOW DPNSS FEATURE CCS SHOW DPNSS ROUTE DETAILED CCS SHOW DPNSS ROUTE SUMMARY CCS TRACE CLEAR CONTEXT CCS TRACE DISABLE CCS TRACE ENABLE CCS TRACE ENABLE CONTINUOUS CCS TRACE SET CONTEXT CCS TRACE SET CONTEXT VIRTUAL CCS TRACE SET CONTEXT XNET CCS TRACE SHOW CONTEXT CCS TRACE SHOW OUTPUT
Meant to include this comment;
Command set provided at no charge. >>>Does anyone have a definitive command tree structure of CCS trace commands
That's brilliant thankyou! It all comes flooding back now... As for the "resulting spew", well I can read that just fine thanks
Cheers, Lee
