Hi all, I am working on a Merlin Magix in our system interoperability lab.
I got the basic outbound calls working, but for some reason calls to '0' or '00' are failing. (dialing 9,0 or 9,00.)
0+10 digits (national with operator assistance) works okay; 01/011 (international) works okay.On the calls to 0 or 00, the Central Office doesn't even see the ISDN setup message; however the Merlin doesn't say 'call denied' like it did when I didn't have the basic programming.
On the ARS table for zero and n11 calls, I have FRL set to 2 and the line pool shows 70. I didn't put that in there, that's the way it came up.
On the default toll and default local it also has FRL 2 and line pool
70, and those calls are completing so I figure that is probably correct.How can I find out for sure what is the correct line pool for my PRI lines?
I am using WinSPM to administer the PBX, I don't have the correct set for set-based administration.
Any help would be appreciated, and I apologize if these are 'dumb' questions! I did look in the documentation, but couldn't figure out where to find this info.
- Samm Hodgeman
