Is the Samsung DS616 a decent system for a home installtion?
Thanjs.
Thanjs.
I've put in a couple dozen of these and have had no trouble with them. Gives you ports for 12 digital phones, 4 analog phones and, depending on the card installed, either 3 or 6 incoming lines, Fairly versatile programming that's easy to do, once you grasp the concept of it. Should be be quite adequate for your average home installation.
Hope this helps.
Take care, Rich
God bless the USA
