Raymer TGSP-4
Hello all,
I am looking for a install manual for a Raymer TGSP-4 Tone Generator. Anybody have a link or something that can be emailed. I tried Google but the top choices don't seem to fit. Searching down the list gets tedious.
TIA
Les
ABLE_1
It's not rocket science. The output is into 600 ohms and you have 2 wires and a switch to select the various inputs, plus a level and pitch control. You can test it with a screwdriver shorted across the pins.
Check out
for a warm and fuzzy picture.
Carl Navarro
Carl Navarro
Carl,
Thanks, that is what I suspected but didn't know what the output was.
Very helpful.
Thanks again.
Les
ABLE_1
