Need source of manuals for Partner Plus #103B8
Threaded View
All,
Can someone give me a source/vendor for manuals for an
AT&T/Lucent/AVAYA Partner Plus Model #103B8 phone switch, and the same
for the Partner Mail VS R4.1 module?
Thanks now,
r
Re: Need source of manuals for Partner Plus #103B8
Reed,
Try www.avaya.com Right now I can't connect to it, but ordinarily you should
be able to find the documentation there. Hope this helps.
Peter.
> All,
> Thanks now,
> r
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com ).
Version: 6.0.726 / Virus Database: 481 - Release Date: 07/22/2004
Check out http://www.tech-man.com
Jim Rojas
Technical Manuals Online!
www.tech-man.com
> Reed,
> should
> Peter.
>> All,
>> Thanks now,
>> r
Reed Loefgren wrote:
> All,
> same
> Thanks now,
> r
You definitely want to go to the source (Avaya) and download it from their
website (below)
http://support.avaya.com/japple/css/japple?PAGE=avaya.css.ProductDetail&temp.groupID=107529&temp.selectedFamily=107548&temp.selectedProduct=107599
Sorry for the ugly URL. In case it does not go through, just go to
avaya.com, then go support->communication systems->Partner->Partner Plus
Same goes for the VM manual, which you can find under
support->messaging->partner mail VS->R4
Good luck!
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.telecom.tech - 4642 messages and counting!
Jim Rojas
www.tech-man.com
> All,
> Thanks now,
> r
Site Timeline
