We've got an old phone system we're looking to replace. I've had good experience with Panasonic in the past (D308 & D1232), so I'm looking at their offerings. We currently have 6 CO lines and
17 sets, so I was looking at the TA824 because it would provide room for growth over the next few years. Features we'd like are voice mail, outside notification, and AA. (AA would be only for after-hours.)One question I have is about voice mail.
The 824 accepts an expansion card that, "provides basic voicemail service, with 2 ports, 24 mailboxes, 60 minutes recording time." But I'm concerned about two VM ports being enough (4 would be better.) Also, Ablecomm says that they don't recommend this card at all and, instead, suggest something like the TVA50 external VM cabinet. OK, except that they also say they do not recommend the TVA50 in anything more than the 2-port configuration on the TA824. So I'm still concerned about having only 2 ports for VM.
Should I scuttle this TA824 idea and look at something bigger like the TAW848, since the D1232 is now discontinued?
Should we look at other brands?
Any advice is welcome!
Thanks.
