Hello all,
I'm looking for a telephone solution for a small psychologist's office. Specifically, I'm looking for a solution which works in the following setting:
- 2 offices
- 3 (analog) phone lines: one common, and one private line per office
- The private lines are shared with fax machines (the fax machines listen for tones as an answering system picks up; this is tested and working.)
The sticking issue with all the solutions that I've come up with so far has been with voicemail. In particular, both offices need to be able to listen to messages on the common lines, but must to be able to *not* listen to messages that came in on the private lines (due to patient confidentiality issues.) I'm not looking for hard security, but enough separation that one won't end up listening in by mistake.
Additionally, concealed space is at a premium (there certainly is no wiring closet), so it is desirable that as little equipment as possible is involved.
Many thanks,
-hpa
