Hi
Can anyone suggest a solution for VOIP .
15 users should be able to connect from location X to location Y. X and Y connected via 2MB leased line.Rgds
Sunil
Hi
Sunil
Hi Sunil
Whats the budget???? as it does make a difference, Personally if the Budget is low then look at Asteisk
Ian
I'd recomend and inter-tel 5000 series system.
The Avaya small office IP just might do the trick.
Carl Navarro
The IP office has a limited future, the range is allready being slashed due to poor sales
Huh? Don't tell Wal*Mart that. They're buying 5 cabinet IPOffice systems in their new stores because "the Magix is gone".
You're gonna have to buy the box and *LIKE* it.
Carl
Huh? Don't tell Wal*Mart that. They're putting IPOffice systems in their new stores, because "The Magix is gone".
You're gonna have to buy the new box and *LIKE* it.
Carl
>You will not beat the Toshiba CIX family on price or functionality
