HP Fax Printer Scanner Copier
Threaded View
I got a call a few days ago about a complaint that a phone line was
"noisy and slow".  Well, I went over to the department, and I used my
buttset to make some calls to other people to see how noisy the line
was, and it seemed just fine to me and the other people.  As far as
being slow, well, this campus is out in the boonies, maybe 5 miles from
the CO, so the lines, if they're hard copper, have loading coils on them
which limit the bandwidth.  People seem to have no problem with that,
but this particular fax machine complained about it when the company
installed the machine.
The fax machine is a HP combination fax, scanner, printer, and copier.
I didn't get the model, but it's a new one that has a flat glass with
lid on the top, just like a copier.  The clerk said that the previous
fax machine worked just fine with the same phone line.  So I don't think
there's a problem with the line other than it's physically longer than
the average.
Apparently the HP hardware and/or software complained about the phone
line quality when it was set up.  Apparently other more normal fax
machines just put up with the phone line limitations and go about their
business.
So yesterday, I heard that this HP combo unit was the second one that
had been installed, after the original one failed.  However, it, too,
had failed!!  Now isn't that pathetic?  Schadenfreude!  :-*
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS?   Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted.  *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff.  alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers.  Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Re: HP Fax Printer Scanner Copier
Probably the HP 3030.
<http://www.shopping.hp.com/webapp/shopping/product_detail.do?storeName=storefronts&landing=photo_scanner&category=all_in_ones&subcat1=see_all&catLevel=2&product_code=Q2666A%23ABA
Hope that url survives usenet posting.  If not, try:
  <http://search.hp.com/query.html?cc=us&lang=en&qt=3030&la=en
And click the first link under "Search results".
I have its brother, the 3015,  essentially the same except for a sheet
fed scanner, not a flat scanner.  Works fine to print, copy and scan,
but I don't use it for faxes.  I have winfax for that.
Rich Greenberg Marietta, GA, USA richgr atsign panix.com    + 1 770 321 6507
Eastern time.  N6LRT  I speak for myself & my dogs only.   VM'er since CP-67
Canines:Val, Red & Shasta (RIP),Red, husky                   Owner:Chinook-L
Atlanta Siberian Husky Rescue. www.panix.com/~richgr/  Asst Owner:Sibernet-L
copier.
think
than
<http://www.shopping.hp.com/webapp/shopping/product_detail.do?storeName =
atLevel=2&product_code=Q2666A%23ABA>
Thanks for the info.  WSe're going to a fax server beginning next year,
so I don't see why they even bought a new fax.  However it's a smaller
dept and when the fax server is implemented, the users will get imcoming
faxes in their outlook email inbox.  Bitch, 'cause of all the junk
faxes.  But in order to originate a fax, the user will have to have a
scanner to get the document into the fax software.  We're deploying
Xerox Workcentres or Docucentres in the bigger depts, but the folks are
already complaining they're a whole lot slower than their old copier,
wasting their time.
Someday I hope to see a filtering software, probably an extension to the
spam filtering, that will eliminate all the junk faxes.  We will be
saving over $2500 a month in fax line costs for the almost 200 fax lines
we have.  So hopefully this new fax server will pay for itself quickly.
Also, one more comment.  I think the gummint should require fax makers
to implement some kind of Turing test option that the receiving fax may
send to the sending fax.  Something like a few voice synthesized digits
that the sender must punch into the dial pad, so that the receiving fax
knows for certain that it's a real human who's sending the fax.  Any fax
number could be added to a number list to bypass this test, so only
uninvited numbers would have to take it.  Also, CallerID could be used
to similarly filter certain numbers.
Well, I can dream, can't I?  Who knows?  Maybe the SOBs will lobby
congress and get them to make another law to protect big businesses
against such a system, just like they did with the FCC and the 47/227
rules they were going to implement.
321 6507
CP-67
Owner:Chinook-L
Owner:Sibernet-L
One thing you can do that will eliminate many of the junk faxes is to
set the fax recieve to not answer until the 8th ring.  Most of the junk
faxers will give up before that many rings.  Most real faxes will try
for 1 min (typically).
Re: HP Fax Printer Scanner Copier - Another Q
year,
smaller
imcoming
junk
Thanks for the info.  I don't know if it's physically possible or
practical to go to almost 200 fax machines and set them to answer like
that.  I know itwould take a single person several days just to do one
campus.  And this assumes that all of the machines have that capability.
And another thought.  If one machine gave up after 6 rings, and could
not me changed, then it would be locked out of sending to any other of
the oness set for 8 rings.  Wew have a lot ot Toshiba faxes, and I hate
them.  They are really difficult to navigate the menues.  I needed the
manual to set up the one in our office.  And there are other brands,
brother, HP, etc., etc., etc.
And one more concern.  Most of our fax machines are on centrex lines,
and we remove the call forwarding on no answer because it saves a buck
or two per month.  But with the fax machines always answering on the
first or second ring, we would never know if the line still has CF on
it.  If the fax machine was then set for 8 rings, the machine would then
never receive a fax if the phone line still had the CF feature.
I guess it would be easy to implement answer on 8 rings with the server.
But only for incoming calls from foreign faxes.
I remember a few years ago seeing a gizmo on the shelves of the stores
about this time of year, before Xmas.  IIRC, it was called the Zapper,
and played some SIT tones into the phone line to try to fool the calling
party's equipment into believing it was a disconnected line.  I wonder
why they are no longer around.  They were about fifty bucks at first,
but might have been cheaper later.  Perhaps the FTC's Do Not Call List
made them no longer needed.  Or maybe the telescammers got wise and made
changes to make the Zapper ineffective.  I was thinking that this same
'feature' might be good on the server for incoming foreign faxes.
Thanks again.
321 6507
http://www.telezapper.com /
FTR I have no connection with them.
I just got one at a thrift store for a buck. Works as advertised, will
send just the first SIT in 'normal' mode, and all 3 in 'advanced'. It's
been in service for around a week, and it seems to be working already. I
think maybe the phone scammers exchange info, cause I used to get 2,3,4
calls a day, haven't had any at all for a few days now. I like it!
Bill Turlock
Site Timeline
