Home phone does not ring on incoming wireless calls
Threaded View
Home cordless phone would not ring so bought a new one with combo of cord and
cordless. Still had the ringing issues. Called phone company and repairman
visited and phone started to ring, but after a while I noticed that wireless
calls were showing as 'missed call' and in the caller ID list. The wireless
calls are not ringing in. Land lines are!
Re: Home phone does not ring on incoming wireless calls
On 8/1/2013 1:55 PM, gysgtawp wrote:
What happens to incoming wireless calls?  Do they ring dead as if going
to an unattached line elsewhere?
Find out more about which calls do and don't reach you.  It is not just
"wireline" vs. "wireless", but which carriers/switches.  For instance, try
a) a call from your same carrier's switch; for instance, if your line is
in East Overshoe and served by the BellNorth Overshoe CO, have another
BellNorth Overshoe line call you.
b) then try a local *cable* or CLEC wire line (not a resale line though)
c) try a long distance call from out of state (have someone call you back)
d) try a couple of different wireless carriers.
It may be a problem with the number portability database.  How long have
you had the number on that carrier?
Site Timeline
