Do someone know where can i get some help for handover mobile cellular simulation for matlab? thx a lot
- posted
18 years ago
You can find sequence diagrams about different types of handovers in GSM at:
Hi thx for the links. do you have any information about handover delay? please. Related handover issues in matlab?
thanks a lot
You can simulate the handover delays using a uniform or poisson random number generator.
I would recommend going through the detailed specifications at the 3GPP website:
-- EventStudio System Designer 2.5 -
Hi, I'm from Vietnam. Now i've a dissertation like u. It's: Understanding handover algorithms and using Matlab for simulating. I think u've graduated and done your dissertation. So, Can you give me your source code which used for your Dissertation!
In my dissertation, i use Pattern recognition. Thanks for your help.
