Hello group!
I ran across a peculiar situation. Hopefully, I can describe it well enough in a newsgroup post...
I was working on a site where some electricians had done the network and telephone cabling. All of the CAT5 network cabling terminated into a cabinet which used a patch panel. From the patch panel, there were small patch cables connecting each live port on the panel to their switch. All of that seemed normal. However, to one side of the patch panel was a plastic box of some type. It took in two CAT5 cables on the front and then had some cabling come out of the back of it. I am guessing that they doubled up one of the cable runs to actually wire two jacks and were using this box to split the line back into two lines which could be connected to the switch. Would this make sense on CAT5 for an ethernet LAN? Is this the best way when there were open ports on the patch panel?
Thanks for any info -- just curious about why this was done this way.
Jonathan
