I am getting a situation where my ISDN Channels are lockedout. When I report to BT that my contact centre equipment is reporting an ISDN error (status 44), BT run their 'robot' diagnostics and no error is detected. However, when I talk to a BT engineer they notice that the robot has reset a number of lockedout channels. My equipment then starts to work properly again.
I am using a Wintel Contact Centre Solution from a company called Vocalcom. This system uses Intel Dialogic Boards for its telephony (PCI DMV600A2E1). From what I understand, BT locksout channels when their equipment thinks it has detected an error in the connected equipment. The strange thing is that this does not happen to all channels at once. I am losing some channels, but others are continuing to work.
Does anyone understand what is meant by channel lockout and how it works?
Has anyone come across similar problems with Dialogic cards?
Thanks,
Andy
