Although this simple and informative article applies to audio, the principle is the same for datacom and telecom.
-- @@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@ ###Got a Question about ELECTRONICS? Check HERE First:###
email address is whitelisted. *All* email sent to it goes directly to the trash unless you add NOSPAM in the Subject: line with other stuff. alondra101 hotmail.com Don't be ripped off by the big book dealers. Go to the URL that will give you a choice and save you money(up to half).
You'll be glad you did! Just when you thought you had all this figured out, the gov't changed it:
