It appears you have a Lucent Partner phone system. On your display phone press "Feature" then 59. Your firmware version should come up. Post it here so people can help you better. Also, dial "intercom" 78 or "intercom"
See if anything answers. That would be your voice mail system if it does. If it does not, Google (or better yet, search eBay) for Partner Mail or Partner Mail VS modules 'cause you will need one if you don't have it yet.
Cheers! DA
##-----------------------------------------------# Delivered via
access to your favorite newsgroup - comp.dcom.telecom.tech - 1749 messages and counting ##-----------------------------------------------##
You are right! F59 trick seem to only work on newer Partner ACS systems. Anyways, yes, a $20 answering machine when hooked up in parallel with the phone will work. You will have to make sure you hook it up to the first pair (central pins of the jack) as the second one carries power to the phone. Actually, any one line phone splitter shoud do since they usually don't have contacts for the second line anyways. Obviously, you would loose capabilities of having your voicemail pickup when you are already on the phone talking to somebody, but that may not be a big deal to you. In general, $20 answering machine approach should work if all you need is a single voice mail box. In other cases, I would still look for a Partner voice mail card for your system.
Cheers! DA
access to your favorite newsgroup - comp.dcom.telecom.tech - 1755 messages and counting ##-----------------------------------------------##
