Adding KX-TD170 to Pana KX 1232 system -- need help
Threaded View
I have installed a KX-TD170 to get 8 more extensions, but I have not
been able to get those new extensions to work at all -- phones have
blank screens.  I found the system setting for what is in each
expansion space (1-3), and set that properly, but there must be
something else I need to do.
Help is much appreciated.
- Barry
bmegdal@shbinstruments.com
Re: Adding KX-TD170 to Pana KX 1232 system -- need help
bmegdal@shbinstruments.com wrote:
It's been a few years since I did this but you might have to reset the
1232 when installing this card. It should be in the installation manual.
If the TD170 is really in the right space (default is either top space),
then they should work.
It should have been installed while the system was powered off, so resetting
may not be needed, but try it again anyway.
Then check you wiring and be sure the connector is in all the way.
Those amphenol connectors can pop out easily. I often put a piece of packing
foam or a wad of tissue behind it when I put the cover on it to help keep
them in.
lastly, the TD170 card might be bad.
(If you are looking for a second hand card that works, let me know, I have a
few.)
charles
at pattcom.com
Site Timeline
