Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by hamilton on September 26, 2004, 1:56 pm
Please log in for more thread options I am looking for a two-wire high-speed DSL modem pair. I have learned online that I need an HTU-C on one end and a HTU-R on the other end. Can anyone make some suggestions about what available. This is for a closed loop video conferencing and data application. Thank You hamilton AT dimensional DOT com | |||||||||||||||||||
Posted by John Cummings on September 26, 2004, 10:20 pm
Please log in for more thread options My employer, an RBOC, uses the HDSL products of Adtran. http://www.adtran.com/ The HTU-C comes in at least three form factors; 220, 3192 and DDM+ for the central office end. The 220 is the largest, the other two are approximately the same smaller size. I don't know if an equipment enclosure for one or two of the 3192 is available; the 19 or 23 inch relay rack holding 14 (220) or 28 (DDM+) HTU-Cs are installed in my CO. They expect 48 to 56 Volts DC in operation, and power the HTU-R over the twisted pair. Each end expects a DSX-1 connection in and out. You can search their site on this CLEI: T1L3XBZAAA. Whether you'd need a CSU/DSU at each end I couldn't say. You've probably already seen an HTU-R in a telephone equipment room on site. Enclosures for two Plugs are common. T1L3W7WAAA Adtran has circuit design software for download. You can readily count on 12,000 feet using 26 gage copper twisted pair, with no taps, using the two-wire models. Four-wire gets more distance. Good luck. John C. | |||||||||||||||||||
Posted by hamilton on September 27, 2004, 12:55 pm
Please log in for more thread options Thanks, I search the web site.
John Cummings wrote: > hamilton wrote:
> >>Hello all,
>> >>I am looking for a two-wire high-speed DSL modem pair. >> >>I have learned online that I need an HTU-C on one end and >>a HTU-R on the other end. >> >>Can anyone make some suggestions about what available. >> >>This is for a closed loop video conferencing and data >>application. >> >>Thank You >> >>hamilton AT dimensional DOT com >
> > My employer, an RBOC, uses the HDSL products of Adtran. > http://www.adtran.com/ > The HTU-C comes in at least three form factors; 220, 3192 and DDM+ for the > central office end. The 220 is the largest, the other two are approximately > the same smaller size. I don't know if an equipment enclosure for one or two > of the 3192 is available; the 19 or 23 inch relay rack holding 14 (220) or > 28 (DDM+) HTU-Cs are installed in my CO. They expect 48 to 56 Volts DC in > operation, and power the HTU-R over the twisted pair. Each end expects a > DSX-1 connection in and out. You can search their site on this CLEI: > T1L3XBZAAA. Whether you'd need a CSU/DSU at each end I couldn't say. > > You've probably already seen an HTU-R in a telephone equipment room on site. > Enclosures for two Plugs are common. T1L3W7WAAA > > Adtran has circuit design software for download. You can readily count on > 12,000 feet using 26 gage copper twisted pair, with no taps, using the > two-wire models. Four-wire gets more distance. > > Good luck. > John C. > > | |||||||||||||||||||
| Similar Threads | Posted |
| WTD: DSL modem pair | September 26, 2004, 1:56 pm |
| Proper installation of an equalizer amplifier on a dry pair/ Western Electric KS-20159-L2 Equalizer Amp | June 26, 2006, 2:39 pm |
| Virtual Modem for VoIP | March 11, 2005, 12:03 am |
| telephone parallel to modem | January 15, 2006, 8:45 pm |
| Alarm on ASMi-52L modem | April 21, 2008, 12:19 am |
| My dial-up modem fantasy | May 21, 2008, 10:50 pm |
| How do I wire up a PC modem to dial a POTS phone line? | August 4, 2006, 8:48 am |
WTD: DSL modem pair
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> application.
> Thank You
