Telecom Technical Voicemail Indicator Lights
Subject Author Date
Voicemail Indicator Lights nr 10-10-07
Posted by nr on October 10, 2007, 7:11 pm
I have VOIP and three phones with voicemail indicator lights.
Currently two of the phones (GE 27933, cordless) have the indicator
light blinking (on base) and the other phone does not. I do not have
any messages in my mailbox. My phone company has confirmed that it is
not sending the signal to light the lights.
Yesterday I unplugged one of the GE phones (both AC and phone lines)
for about an hour and the light came on when I replugged it in.
Does anyone know a way to turn off these lights on the GE phones? Or
should I just leave them unplugged for a longer period?
Thanks for any help.
Posted by Gary on October 12, 2007, 8:14 pm
Some phones have a magic key sequence or hidden button that can be used to
turn the VM waiting light off. Check your manual. If you don't have a
manual, try google.
If the phone doesn't have this feature or you can't figure it out, try
getting a voice mail and letting the VM system set the lights on all your
phones. Then, delete the voice mail and see if the VM system clears the
lights.
-Gary
Similar ThreadsPosted
Voicemail Indicator Lights October 10, 2007, 7:11 pm
Merlin Legend Mail Message Lights July 13, 2007, 10:41 am
NEC Elite voicemail help October 13, 2004, 12:36 am
Comdial FX VoiceMail dissapeared August 11, 2004, 9:15 am
voicemail integration problem June 26, 2005, 10:12 pm
Unity Voicemail Servers September 30, 2006, 8:07 pm
auto attendant/voicemail March 21, 2007, 3:52 am
Centralized voicemail for large company July 13, 2004, 4:50 pm
Merlin Magix not going to voicemail for 1 extension January 23, 2006, 4:46 pm
voicemail question for avaya partner May 25, 2006, 3:22 pm
Panasonic TDA-50 phone with TVA-50 voicemail questions September 12, 2008, 10:15 am
TVA-50 Voicemail software (TVA Maintenance Console) September 18, 2008, 8:06 pm
Toshiba Strata DK40i - voicemail advice October 3, 2004, 11:32 pm
Toshiba Strata CTX28 Voicemail issue February 11, 2008, 2:43 pm
TVA-50 Voicemail question (concerning LAN card e-mail capabilities) September 16, 2008, 5:52 pm
