Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by WQ on September 6, 2004, 9:48 pm
Please log in for more thread options I am a newbie when it comes to VOIP. I wanted to use VOIP in our small office environment. Existing setup involves three analog lines coming to my office. They go into a PBX, and from there on, we have our individual phones connected. Of course the three lines are in a hunt group, so an outside caller calls the same number. I called Vonage having the same type of setup. Vonage told me VOIP does not work like that. I will have to get an IP phone for each individual in the office. They do have some kind of hunt group, but not similar to normal hunt group. I have the following questions to you experts: 1. Can someone please draw anaology of VOIP with my existing setup. Okay, I understand that there is something in the phone, which over a braodband connection identifies itself to the phone provider (Let us take Vonage in our example). 2. If the above construct is true then I am sure someone would have thought of SOHO environment, where a 3 line VOIP PBX would basically have three identities for Vonage to route the calls. I would greatly appreciate if someone would please comment on my questions. Thanks. Ash | ||||||||||||||||||||||
Posted by John McHarry on September 7, 2004, 3:44 am
Please log in for more thread options Check out Packet8's offering. It might be something like you are looking for. Be aware that you will have more downtime with VOIP. If you want three POTS lines, you will still have to have three interfaces, even if somebody builds them into one box to replace your key system. | ||||||||||||||||||||||
Posted by Kyler Laird on September 8, 2004, 2:10 am
>work like that. I will have to get an IP phone for each individual in the >office. They do have some kind of hunt group, but not similar to normal >hunt group. I've confirmed that I can receive multiple simultaneous incoming calls with BroadVoice. (I did very little testing with it but I'm likely to try it again.) If you're going to try to do anything interesting, I recommend sticking with a more open service (like BroadVoice or VoicePulse). >I have the following questions to you experts:
I'm no expert but if you run a simple Asterisk box at the office with all of your phones connected to it, you should be able to have it register with a service like BroadVoice so that incoming calls ring to the phones as you like (all at once or in rotation). >2. If the above construct is true then I am sure someone would have thought
>of SOHO environment, where a 3 line VOIP PBX would basically have three >identities for Vonage to route the calls. Unless your DID (incoming PSTN) provider limits it, there's no need to think in terms of "3 lines". --kyler | ||||||||||||||||||||||
Posted by shido on September 21, 2004, 10:23 pm
Please log in for more thread options NuFone doesnt limit the amount of inbound or outbound calls you can make and
we are Asterisk friendly. -- Greg Merriweather The NuFone Network greg@nufone.net (877) 677-9649 IM: shido6@msn.com >
>>not >>work like that. I will have to get an IP phone for each individual in the >>office. They do have some kind of hunt group, but not similar to normal >>hunt group. >
> I've confirmed that I can receive multiple simultaneous incoming calls > with > BroadVoice. (I did very little testing with it but I'm likely to try it > again.) > > If you're going to try to do anything interesting, I recommend sticking > with a more open service (like BroadVoice or VoicePulse). > >>I have the following questions to you experts:
> I'm no expert but if you run a simple Asterisk box at the office with all > of your phones connected to it, you should be able to have it register > with a service like BroadVoice so that incoming calls ring to the phones > as you like (all at once or in rotation). > >>2. If the above construct is true then I am sure someone would have
>>thought >>of SOHO environment, where a 3 line VOIP PBX would basically have three >>identities for Vonage to route the calls. >
> Unless your DID (incoming PSTN) provider limits it, there's no need to > think in terms of "3 lines". > > --kyler | ||||||||||||||||||||||
Posted by Scott Nelson - Wash DC on September 8, 2004, 3:15 pm
Please log in for more thread options Vonage will do hunt groups.
All Vonage numbers have to be on the same account. http://www.vonage.com/features.php?feature=call_hunt You will need to ( via online account manager ) disable call waiting to do this but it should work. Scotty > Folks,
my
> > I am a newbie when it comes to VOIP. I wanted to use VOIP in our small > office environment. Existing setup involves three analog lines coming to > office. They go into a PBX, and from there on, we have our individual
not
> phones connected. Of course the three lines are in a hunt group, so an > outside caller calls the same number. > > I called Vonage having the same type of setup. Vonage told me VOIP does > work like that. I will have to get an IP phone for each individual in the
I
> office. They do have some kind of hunt group, but not similar to normal > hunt group. > > I have the following questions to you experts: > > 1. Can someone please draw anaology of VOIP with my existing setup. Okay, > understand that there is something in the phone, which over a braodband
thought
> connection identifies itself to the phone provider (Let us take Vonage in > our example). > > 2. If the above construct is true then I am sure someone would have > of SOHO environment, where a 3 line VOIP PBX would basically have three
questions.
> identities for Vonage to route the calls. > > I would greatly appreciate if someone would please comment on my >
> Thanks. > > Ash > > | ||||||||||||||||||||||
VOIP in a small office environment
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> my
> not
> hunt group.
