Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by HeyHerk@gmail.com on June 2, 2006, 11:51 pm
Please log in for more thread options Does anyone have the pinout for the dongle used to access the DK424's admin? It goes from a 4-pin RJ-25 to a DB-9 I am guessing. Also, I guess while I am at it, anyone have the software? | ||||||||||||||||
Posted by Rich Piehl on June 3, 2006, 9:38 am
Please log in for more thread options HeyHerk@gmail.com wrote: Here's the pinout from the DK 424 manual: 6 pin mod plug end DB25 RS 232 lead name 6 3 RD 5 2 TD 4 6 DSR 3 20 DTR 2 8 CD 1 7 SG Jumper 4 & 5 together on the DB 25 RTS to CTS Do you have the DkAdmin software hardlock for the parallel port? Without it the software is useless. Take care, Rich God bless the USA -- To all veterans and active military personnel: Thank you for your service! | ||||||||||||||||
Posted by HeyHerk@gmail.com on June 4, 2006, 11:36 am
> > admin? It goes from a 4-pin RJ-25 to a DB-9 I am guessing. Also, I > > guess while I am at it, anyone have the software? > > >
> Here's the pinout from the DK 424 manual: > > 6 pin mod plug end DB25 RS 232 lead name > 6 3 RD > 5 2 TD > 4 6 DSR > 3 20 DTR > 2 8 CD > 1 7 SG > > Jumper 4 & 5 together on the DB 25 RTS to CTS > > Do you have the DkAdmin software hardlock for the parallel port? > Without it the software is useless. > > Take care, > Rich > > God bless the USA > > -- > To all veterans and active military personnel: Thank you for your service! I don't have the software yet either, I just took over the maintenance on an existing DK424 last week. Avaya and Samsung are particularly my preference, with Nortel being on my able to do list, but when it comes to Toshiba, I am somewhat disoriented. Any idea where I can get the software? | ||||||||||||||||
Posted by Rich Piehl on June 4, 2006, 12:32 pm
>>>admin? It goes from a 4-pin RJ-25 to a DB-9 I am guessing. Also, I >>>guess while I am at it, anyone have the software? >>> >>
>>Here's the pinout from the DK 424 manual: >> >>6 pin mod plug end DB25 RS 232 lead name >>6 3 RD >>5 2 TD >>4 6 DSR >>3 20 DTR >>2 8 CD >>1 7 SG >> >>Jumper 4 & 5 together on the DB 25 RTS to CTS >> >>Do you have the DkAdmin software hardlock for the parallel port? >>Without it the software is useless. >> >>Take care, >>Rich >> >>God bless the USA >> >>-- >>To all veterans and active military personnel: Thank you for your service! >
> > I don't have the software yet either, I just took over the maintenance > on an existing DK424 last week. Avaya and Samsung are particularly my > preference, with Nortel being on my able to do list, but when it comes > to Toshiba, I am somewhat disoriented. Any idea where I can get the > software? > You might be able to find it if you can find a dealer who is getting out of the Toshiba line and wants to get rid of his hardlock as well as the software. Or you might check on line for Toshiba equipment refurbishers. The only other place you're going to be able to get a functioning copy is from Toshiba Telecom. You can do the programming through a keyset - IMHO that's actually preferable for everything except DID programming or large LCR setups. It's similar to Samsung programming in that once you learn the program numbers for the most common programming functions you don't have to go running for a book or setting up a laptop every time you want to make a small change. It is definitely easier to program the keyset buttons with keyset programming than through DKAdmin. Take care, Rich God bless the USA -- To all veterans and active military personnel: Thank you for your service! | ||||||||||||||||
| Similar Threads | Posted |
| Toshiba Strata DK424 console interface dongle pinout. | June 2, 2006, 11:51 pm |
| Toshiba strata CTX28 | November 5, 2004, 1:37 am |
| Toshiba Strata CTX670 | April 21, 2008, 10:20 pm |
| Hook flash on a Toshiba Strata DK40? | September 8, 2004, 5:01 pm |
| Toshiba Strata DK40i - voicemail advice | October 3, 2004, 11:32 pm |
| Toshiba Strata DK280: Flexible Key for MW-FLASH now lit: Why? | October 17, 2005, 12:49 pm |
| Toshiba Strata CTX28 Voicemail issue | February 11, 2008, 2:43 pm |
| Toshiba Strata 424 Night/Day mode feature access code question | May 30, 2006, 10:55 am |
| System 25 pinout for RS-232 | August 28, 2004, 10:44 pm |
| Need serial pinout for Siemens Hicom 120 | October 16, 2006, 3:35 am |
| Power supply pinout for Lucent Partner? | September 26, 2005, 12:05 pm |
| Meridian M7310 / M7208 Pinout RJ11 | May 10, 2007, 9:36 am |
| pcs phone trunk interface | June 13, 2005, 9:17 am |
| Hosted IVR with API or web interface desired | March 31, 2007, 5:27 pm |
| USB to RJ-45 console cable? | April 4, 2005, 1:41 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
