Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by RXJR on August 30, 2004, 9:50 am
Please log in for more thread options problem. I had my Call Forwarding stored on one of the Auto Dial Buttons. Now the button doesn't work, so I went through the re-store procedure(FEATURE +0 0, etc.) but it doesn't seem to store there. It will auto-dial the call forwarding sequence only once, and then become inoperative again. Apparently it isn't "saving" the sequence, and I have to manually go through the Call Forwarding procedure every time. Can some one help me with this problem please?? | ||||||||||||||||||||||
Posted by Dmitri(Cabling-Design.com on August 31, 2004, 1:19 am
Please log in for more thread options You have to set it up first, and then enable it. Are you programming it to a button with a light? If so, you should see a green light if the function is enabled. If there is no light, just press the button again. Here is an exerpts from Partner 3 programming manual(I picked version 3 for whatever reason , but you should have posted your processor version here): From the System phone: To program a Call Forwarding button: 1. Press feature 0 0 sys.prog sys. prog. central tel program at extension 10 or 11. 2. Enter the number of the extension to be programmed with this feature. 3. Press a programmable button, preferably a button with lights. 4. At this point, you can do one of the following: n Press f 1 1. n Press f 1 1 and the number of the originating extension. n Press f 1 1, the number of the originating extension, and the number of the destination extension. 5. Program another button for this extension or exit programming mode. Standard Phone To forward your calls: 1. Lift the handset. You hear intercom dial tone. 2. Press # 1 1. 3. Dial your extension number. 4. Dial the number of the extension at which you want your calls to ring. To remove Call Forwarding: 1. Lift the handset. You hear intercom dial tone. 2. Press # 1 1. 3. Dial your extension number twice. -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.telecom.tech - 4625 messages and counting! ##-----------------------------------------------## | ||||||||||||||||||||||
Posted by RXJR on August 31, 2004, 1:25 am
Please log in for more thread options Thanks for the prompt reply Dimitri.
You say I must set it up and enable it first...I don't use extensions, and have only had this Call Forwarding sequence programmed into the "master station". When I first set it up several years ago, I think I just used the sequence: 1. Press Feature 0 0 2. Press the desired Auto Dial button (no lights on the button) 3. Dial in the Call Forwarding telephone number 4. Press Feature 0 0. The Call Forwarding (and separate Call Forwarding cancel Auto Button) worked o.k. for several years, until they stopped functioning recently. I tried this same set up again, and it will save it for one use, then nothing. I have the PARTNER manual, Release 4.0, and followed "Changing Settings at the User's Phone", steps 1, 2, 3 and 5 on page 5-4 I don't find a "sys.prog" or "central.tel program" buttons mentioned in your instructions. Does this change your thoughts??? - - - - n9ejs@yahoo.com (RXJR) wrote in message > I have a PARTNER MLS-12 system which has suddenly developed a small
> problem. I had my Call Forwarding stored on one of the Auto Dial > Buttons. Now the button doesn't work, so I went through the re-store > procedure(FEATURE +0 0, etc.) but it doesn't seem to store there. It > will auto-dial the call forwarding sequence only once, and then become > inoperative again. Apparently it isn't "saving" the sequence, and I > have to manually go through the Call Forwarding procedure every time. > Can some one help me with this problem please?? | ||||||||||||||||||||||
Posted by Dmitri(Cabling-Design.com on August 31, 2004, 6:37 pm
RXJR wrote: > Thanks for the prompt reply Dimitri.
> and have only had this Call Forwarding sequence programmed into the > "master station". When I first set it up several years ago, > I think I > just used the sequence: > 1. Press Feature 0 0
> 2. Press the desired Auto Dial button (no lights on the button) > 3. Dial in the Call Forwarding telephone number > 4. Press Feature 0 0. > The Call Forwarding (and separate Call Forwarding cancel Auto Button)
> worked o.k. for several years, until they stopped functioning > recently. I tried this same set up again, and it will save it for one > use, then nothing. > I have the PARTNER manual, Release 4.0, and followed "Changing
> Settings at the User's Phone", steps 1, 2, 3 and 5 on page 5-4 > I don't find a "sys.prog" or "central.tel program"
> buttons mentioned > in your instructions. Does this change your thoughts??? > - - - -
>> small >> problem. I had my Call Forwarding stored on one of the Auto Dial >> Buttons. Now the button doesn't work, so I went through the >> re-store >> procedure(FEATURE +0 0, etc.) but it doesn't seem to store there. >> It >> will auto-dial the call forwarding sequence only once, and then >> become >> inoperative again. Apparently it isn't "saving" the >> sequence, and I >> have to manually go through the Call Forwarding procedure every >> time. >> Can some one help me with this problem please?? "System Program" and "Central Tel Program" are just labels that come from the programming overlay. On the actual phone they are intercom 1 for system and intercom 2 for central tel. I'm not quite sure why it does not store the settings that you set up. I am aware of memory loss on power failure problem on older systems, but if you are sure the power to the system was not interrupted, this would not be the case. In any case, I noticed that you use a no-light button. Call forwarding is for sure one of the functions you want to program onto a button WITH light. This way you always know if it's enabled or not. Hope this helps. -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.telecom.tech - 4633 messages and counting! ##-----------------------------------------------## | ||||||||||||||||||||||
Posted by Touch Tone Tommy on September 1, 2004, 12:22 am
Please log in for more thread options On Tue, 31 Aug 2004 15:37:48 GMT,
info_at_cabling-design_dot_com@foo.com (Dmitri(Cabling-Design.com)) wrote: >
>RXJR wrote: > >> Thanks for the prompt reply Dimitri.
>> and have only had this Call Forwarding sequence programmed into the >> "master station". When I first set it up several years ago, >> I think I >> just used the sequence: >
>> 2. Press the desired Auto Dial button (no lights on the button) >> 3. Dial in the Call Forwarding telephone number >> 4. Press Feature 0 0. >
>> worked o.k. for several years, until they stopped functioning >> recently. I tried this same set up again, and it will save it for one >> use, then nothing. >
>> buttons mentioned >> in your instructions. Does this change your thoughts??? >
>>> small >>> problem. I had my Call Forwarding stored on one of the Auto Dial >>> Buttons. Now the button doesn't work, so I went through the >>> re-store >>> procedure(FEATURE +0 0, etc.) but it doesn't seem to store there. >>> It >>> will auto-dial the call forwarding sequence only once, and then >>> become >>> inoperative again. Apparently it isn't "saving" the >>> sequence, and I >>> have to manually go through the Call Forwarding procedure every >>> time. >>> Can some one help me with this problem please?? >
>"System Program" and "Central Tel Program" are just labels that come from >the programming overlay. On the actual phone they are intercom 1 for >system and intercom 2 for central tel. > >I'm not quite sure why it does not store the settings that you set up. I >am aware of memory loss on power failure problem on older systems, but if >you are sure the power to the system was not interrupted, this would not >be the case. > >In any case, I noticed that you use a no-light button. Call forwarding is >for sure one of the functions you want to program onto a button WITH >light. This way you always know if it's enabled or not. > >Hope this helps. It sounds to me like the original poster is talking about programming an outside speed dial on a button that dials the "varible call forwarding" string to forward incoming calls to the answering service. Ya know, "72#p5551212", and to cancel, (on another button), "73#". Now, the sequence is to go the the particular phone that you want to program these button onto, and with the handset in the cradle, Feature 00 Press the button Dial the telephone number (using "Hold" for pause) Feature 00 If you have a display phone, press the button once again after you dial the telephone number, and you can confirm that the sequence has been stored. | ||||||||||||||||||||||
PARTNER MLS-12 phone system problem
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> sequence, and I
