Telecom Technical Outgoing Caller ID Blocking
Subject Author Date
Outgoing Caller ID Blocking Joe Tillery 07-13-06
Posted by Joe Tillery on July 13, 2006, 10:20 am
We have a DK424 phone system with a PRI. We have the system blocking
all outgoing caller id. The problem I am having is I cannot find the
feature code to selectively override the caller id block. The system
is programmed to allow the override.
Thanks,
Joe
Posted by Rich Piehl on July 23, 2006, 3:37 pm
> Thanks,
> Joe
There is no feature code to override the caller ID block.
What you may be able to do is set up two separate routes in LCR, one
with the caller ID block code and one without it. When a a call needs
to be placed with the outgoing caller ID the caller would access the
separate trunk group.
I'm not sure whether this would work - I'd have to do some playing with it.
Take care,
Rich
God bless the USA
To all veterans and active military personnel: Thank you for your service!
Posted by Joe Tillery on July 31, 2006, 5:09 pm
> Take care,
> Rich
> God bless the USA
Rich,
Thanks for the idea. You are definitely onto something here. We have
2 POTS lines for backup setup on the 2nd trunk. They are set to show
outbound caller ID. We can just use those when we need to make calls
with an unblocked number. When the technician programmed the system,
he showed me an access code to go the 2nd trunk, but I cannot find it
in my notes. Do you know what it is?
Thanks,
Joe
Posted by Joe Tillery on August 1, 2006, 6:45 am
> Thanks,
> Joe
I actually figured it out. The POTS lines are Line 25 and 26, so we
need to dial #7025 or #7026 to access them.
Thanks
Posted by Rich Piehl on August 1, 2006, 8:06 pm
>>Take care,
>>Rich
>>God bless the USA
> Rich,
> Thanks,
> Joe
Glad I could help.
Take care,
Rich
God bless the USA
Similar ThreadsPosted
Outgoing Caller ID Blocking July 13, 2006, 10:20 am
algorithm for handling outgoing calls February 22, 2005, 2:22 am
Avaya Partner ACS - Need help with Outgoing calling August 24, 2007, 9:31 am
Caller ID ??? April 7, 2006, 12:11 am
Caller-ID December 4, 2006, 4:21 am
Caller ID January 9, 2007, 10:56 pm
Sending a different caller ID November 29, 2004, 2:43 pm
Understanding caller ID October 23, 2005, 8:11 pm
CTI Caller ID Capture January 31, 2006, 12:56 pm
NEC DS 2000 - no caller id April 11, 2006, 7:22 am
Truth in Caller ID Act April 11, 2007, 4:50 pm
Caller ID disappears June 11, 2008, 6:27 pm
Partner ACS 6 and a T1 module for DID & Caller ID August 19, 2004, 5:03 pm
Caller ID Name Delivery (CNAM) November 10, 2004, 2:12 pm
UK Caller ID test equipment November 22, 2004, 2:03 pm
