Telecom Technical Old Lucent Technologys ACS Partner tech question.
Subject Author Date
Old Lucent Technologys ACS Partner tech question. Jerry Dorf 06-05-07
Posted by Jerry Dorf on June 5, 2007, 1:53 pm
The company I work for recently aquired a company that has a partner phone
system.
Not being familair with the Lucent ACS systems, how will it react to removing 2
CO lines
without reprograming? It appears that each phone has buttons for each CO line
like a key
system.
My experence is with the panasonic KX-T systems.
Thanks
Jerry
Posted by Rich Piehl on June 5, 2007, 3:36 pm
system.
2 CO lines
like a key
> system.
> Thanks
After you remove the lines the buttons corresponding to those lines will
still function. You'll just get 'dead air' when they're pressed.
The question mark will be how the phones are programmed for off-hook
select. If they are programmed for intercom dial tone - no problem. If
you are removing lines 5 & 6 and they are programmed to sequentially
select 1,2,3,4 no problem. If they are programmed to go off hook to
line 5 or 6 and you are removing 5 & 6 every time they go off hook
they're going to get dead air. Their off hook selection will need to be
reprogrammed.
Also of issue is if they are set to use pool lines and the removed lines
are part of the pool. Or if speed dials are set to go out on the
removed lines. Again, selecting those lines will give you 'dead air.'
Hope this helps.
Take care,
Rich
God bless the USA
Et in terra pax
Similar ThreadsPosted
Old Lucent Technologys ACS Partner tech question. June 5, 2007, 1:53 pm
Avaya Partner Messaging tech login March 4, 2005, 10:59 pm
lucent partner plus R4.1 with vs mail 4.0 I'm at my witt's end..Please help me April 8, 2006, 6:51 pm
Lucent Partner Voice Mail August 28, 2006, 7:45 pm
Power supply pinout for Lucent Partner? September 26, 2005, 12:05 pm
Panasonic 824 / TVS 50 tech question March 10, 2007, 5:14 pm
Panasonic TES824 Tech question November 17, 2006, 7:34 am
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In January 12, 2008, 2:11 pm
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In February 15, 2008, 9:51 pm
Re: I BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, I September 11, 2008, 7:51 pm
voicemail question for avaya partner May 25, 2006, 3:22 pm
I am looking to buy Cisco, Lucent, Nortel, Alcatel, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Intel, Motorola, Nokia VPN/Firewall, Netscreen, Microsoft Adobe, February 24, 2008, 8:22 am
Partner System - Analog Extension Question August 4, 2005, 8:24 am
Voice Mail question on Avaya Partner April 25, 2006, 1:14 pm
