Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Henry Cabot Henhouse III on December 8, 2004, 11:46 pm
Please log in for more thread options Anyone know of a way to do more than 10 CPN Subs? I have 20 tenants on a 200, and I need to sub all 20 did ranges. Oh... and were upgrading to PRI on our SX2000 ML... I haven't seen the CDE for the PRI... are there subs for that? Thanks! | ||||||||||||||||
Posted by on December 9, 2004, 11:29 pm
Please log in for more thread options >LW 19.3 PRI
>200, and I need to sub all 20 did ranges. >Oh... and were upgrading to PRI on our SX2000 ML... I haven't seen the CDE
>for the PRI... are there subs for that? >Thanks!
I don't have my ISDN docs handy Dave, but whatever the max CPN substitutions is, it's not expandable. If you have more than one ISDN span you could always build some class of restriction (or interconnect restriction) to funnel part of your tenants toward one hybrid and the rest toward another. In that way you could effectively double the number of available CPN subs. More work sure, but possibly a means to an end. Both the SX2K and the SX200 PRI ISDN software is built from the same core, both running on vxWorks. Features and limits will therefore be similar, if not identical. | ||||||||||||||||
Posted by K8JLF on December 12, 2004, 11:16 am
Please log in for more thread options >Both the SX2K and the SX200 PRI ISDN software is built from the same core,
>both running on vxWorks. Features and limits will therefore be similar, if >not identical. Really...That may or may not answer a question I had about a large mitel system I bought that I'll probably need to reset the password on. Now I know there are a number of ways to run VxWorks, both with a visible file structure or without. Can the SX-200 be stopped at a boot monitor prompt (like VxWorks based systems normally can be) and a file in the filesystem modified or deleted to rid it of passwords? If so, which one is it? I've done this before on other systems from other manufacturers. | ||||||||||||||||
Posted by on December 12, 2004, 2:26 pm
Please log in for more thread options (K8JLF) writes:
>I bought that I'll probably need to reset the password on. Now I know there are >a number of ways to run VxWorks, both with a visible file structure or without. >Can the SX-200 be stopped at a boot monitor prompt (like VxWorks based systems >normally can be) and a file in the filesystem modified or deleted to rid it of >passwords? If so, which one is it? >I've done this before on other systems from other manufacturers.
On the SX-200ICP almost immediately after POST there's a 10-sec pause (even an onscreen prompt with a 10-sec countdown) where you can hit any key to interrupt it. I dunno about the file structure or if you can do any tinkering, but you can definitely interrupt the boot process. That's how you get in to set the network IP parameters. Type the "@" symbol followed by the [enter] key to resume booting. When you find out, let us know ;-) | ||||||||||||||||
Posted by on January 11, 2005, 7:49 pm
>LW 19.3 PRI
>for the PRI... are there subs for that? Dave, we just today did some upgrades to several of our PRI cards for our SX2K "farm". You might be interested to learn that in the most recent PRI card loads that TWO HUNDRED (200) cpn subs are now supported. I'll have to look at the docs to see what load of switch s/w is supported. Your LW19 box is surely OK, but your SX2K box may need that long overdue upgrade. | ||||||||||||||||
| Similar Threads | Posted |
| Mitel SX200 CPN Substitution | December 8, 2004, 11:46 pm |
| Mitel SX200 and CESID | July 1, 2008, 11:51 pm |
| Mitel SX200 - How to Master Initialize | October 16, 2007, 4:16 pm |
| New CO , Mitel SX200 ground start problems | February 20, 2008, 9:01 pm |
| sx200 pri and cim | August 25, 2005, 8:43 am |
| sx200 ml/el lw 19.2 questions | July 13, 2004, 4:25 pm |
| sx200 pri question | March 18, 2006, 1:19 am |
| sx200 ml/el lw19 q45 question | July 4, 2005, 3:55 am |
| sx200 ml/el w/PRI cfwd external | August 11, 2004, 2:29 am |
| SX200 & 2000 T1/DMS Question | September 6, 2004, 1:51 pm |
| SX2000 to SX200 T1 Tie Line | July 11, 2005, 2:55 am |
| SX200 / 2000 AAN Question | July 3, 2006, 6:13 pm |
| SX200 2000 Tie Line/Pri | September 18, 2006, 3:51 pm |
| MITEL SX2000 | August 5, 2004, 7:12 am |
| Mitel SX2000 | August 5, 2004, 9:28 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
