Telecom Technical Distinctive Ring Answering?
Subject Author Date
Distinctive Ring Answering? aw 09-14-04
Posted by aw on September 14, 2004, 10:57 pm
Anyone know of a answering machine (alone or combo) that will play 2
different outgoing messages based on the phone company's distinctive ring
service?
I had a phonemate for years, but I think it's time has come and cant' find
anything to replace it.
Thanks,
Adam
Posted by Rich Piehl on September 14, 2004, 10:55 pm
> service?
> Thanks,
> Adam
Don't know of any answering machine that will detect distinctive ring.
But you could use an SR 2 or 3 to detect them and then use conventional
answering machine for he ring type.
Take care,
Rich
God bless the USA
"I'd rather have a full bottle in front of me than a full frontal lobotomy."
---Fred Allen---
Posted by GlowingBlueMist on September 14, 2004, 11:33 pm
> service?
> find anything to replace it.
> Thanks,
> Adam
You might try one of the small distinctive ring phone switches like the
Comswitch CS5500 (Less than $70) shown in the link below.
http://www.powersystemsdirect.com/Command_Communications/Distinctive_Ring_Switch_3_Port_Voice_Fax_CS5500_1277.php
You might need to verify the output ring the ports provide but if the box
converts the distinctive ring into a standard ring pattern you could use
standard cheap single line answering machines on the output ports.
I believe they even have a CS7500 model that supports up to 4 devices should
your line support 4 different distinctive rings.
/// GlowingBlueMist
Posted by GlowingBlueMist on September 14, 2004, 11:35 pm
> service?
> Thanks,
> Adam
/// GlowingBlueMist (Remove the zap for my direct email address)
Posted by Tim Keating on September 15, 2004, 1:44 pm
>service?
There are several PC based software packages which when tied to a
voice/data/fax modem allow different responses based on distinctive
ring pattern.
For example..
I've got the primary ring which forwards into voice email system,
which requires additional responses to leave a message(human detection
test). A call on the 2nd phone number, makes a distinctive ring
activates the incoming fax function.
Similar ThreadsPosted
Distinctive Ring Answering? September 14, 2004, 10:57 pm
answering machine on partner plus system doesn't ring May 21, 2008, 2:11 pm
Why does verizon cellphone voicemail pick up after the 5th ring, other times at the 1st ring. October 14, 2008, 5:20 pm
Answering Message on MLS-12D? July 6, 2005, 2:14 pm
AT&T Lucent Answering Machine #1710? November 4, 2004, 12:54 pm
2-line; 2 message Answering machines June 25, 2006, 9:02 pm
"Ring-master" in CA March 28, 2005, 10:39 pm
First Ring Supression? January 5, 2006, 7:23 pm
Looking For Used 016 Module With Ring Gen For Merlin System April 14, 2008, 10:17 am
Partner Mail (release 3) simultaneous ring December 8, 2004, 4:26 pm
Making incoming calls also ring a phone line in remote office? April 23, 2006, 6:53 pm
