Telecom Technical Different clock sources for STM-1 and E1 ??
please rate
this thread
Posted by René Hüftlein on January 9, 2012, 10:21 am
Hi!
Maybe someone here can help me with a problem we have with our PSTN
gateway.
We receive 63 E1's channelized into a STM-1. The E1's are provided by
DTAG (German PSTN) and are multiplexed into the STM-1 provided by
Verizon. STM-1 directly terminates in a Audiocodes Mediant 3000 which
demultiplexes STM-1 and routes E1's respectively.
We see a huge number of Controlled Slips (one in 20 seconds) and it
seems this condition causes fax calls to crash.
We got in contact with Verizon and they told us, that they are
receiving DTAG's E1's in sync with a PDH clock and transparently
multiplex that into the STM-1 which is clocked by a different master
clock. (As it is not their policy to generate clock from external
sources and PDH can not be used for SDH clock source - that's what
they said)
[For what I read on the interwebs SDH was specially designed to
support relaying of PDH - so I don't really get the point...]
So we receive E1's and STM-1 on different source clocks. Unfortunately
Audiocodes tells us the gateway only supports one single clock source,
which has to be the STM-1 or any external clock directly connected to
the device.
I appreciate any hints or tips on this issue (or any lesson on PSTN
clocking) as I am used to deal with IP networks on the very higher
layers...
Cheers Ren=E9
Posted by Bill Matern of NComm, Inc. on January 13, 2012, 9:52 am
When=20setting=20up=20a=20system=20that=20transports=20E1s=20over=
=20an=20STM-1=20interface,=20you=20can=20use=20one=20clock=20for=
=20the=20STM-1=20interface=20and=20a=20different=20clock=20for=20t=
he=20E1=20interface.=20These=20two=20clocks=20should=20be=20locked=
=20to=20each=20other=20and=20be=20derived=20from=20the=20same=20so=
urce,=20but=20do=20not=20have=20to=20be=20which=20your=20case=20is=
=20=e2=80=93=20The=20E1=20clock=20from=20DTAG=20and=20the=20SDH=20=
from=20Verizon=20are=20not=20locked=20to=20each=20other.
=20
The=20source=20of=20your=20slips=20is=20coming=20from=20the=20mis-=
match=20of=20these=20two=20clock=20rates.=20=20What=20is=20happeni=
ng=20is=20that=20on=20your=20Audiocodes=20receive=20side,=20it=20i=
s=20receiving=20the=20STM-1=20and=20de-multiplexing=20it=20into=20=
E1s.=20=20The=20differences=20in=20frequencies=20of=20the=20STM-1=
=20and=20the=20E1=20are=20dealt=20with=20pointer=20justifications=
=20happening=20at=20the=20TU-12=20path=20level=20(A=20TU-12=20is=
=20what=20is=20used=20to=20transport=20an=20E1=20over=20a=20SDH=20=
network=20=e2=80=93=20you=20have=2063=20TU-12=20paths=20=e2=80=93=
=20one=20for=20each=20E1).=20=20Since=20these=20frequencies=20are=
=20different,=20if=20your=20Audiocodes=20box=20does=20performance=
=20monitoring,=20you=20should=20be=20able=20to=20look=20for=20poin=
ter=20changes=20at=20the=20TU-12=20level=20to=20see=20that=20these=
=20two=20clocks=20are=20different.
=20
Pointer=20changes=20are=20not=20the=20same=20as=20slips.=20=20A=20=
slip=20occurs=20when=20the=20receive=20clock=20on=20the=20E1=20is=
=20different=20from=20the=20system=20clock=20in=20your=20Audiocode=
s=20box.=20=20Inside=20the=20E1=20framer=20of=20the=20Audiocodes=
=20box,=20there=20is=20a=20block=20of=20memory=20that=20the=20time=
slots=20of=20the=20E1=20are=20stored=20as=20they=20arrive=20on=20t=
he=20E1=20using=20the=20receive=20E1=20clock=20rate.=20=20The=20ti=
meslots=20are=20then=20readout=20of=20this=20block=20of=20memory=
=20at=20the=20system=20clock=20rate.=20=20NOTE:=20This=20block=20o=
f=20memory=20is=20called=20the=20elastic=20store=20or=20slip=20buf=
fer.=20=20=20So,=20what=20happens=20when=20the=20rate=20of=20times=
lots=20arriving=20on=20the=20E1=20is=20faster=20than=20the=20syste=
m=20takes=20them=20out.=20=20Since=20there=20is=20not=20infinite=
=20memory,=20the=20E1=20framer=20will=20do=20a=20controlled=20slip=
=20which=20would,=20in=20this=20case,=20would=20delete=20an=20enti=
re=20frames=20worth=20of=20timeslots.=20=20Conversely,=20if=20the=
=20rate=20of=20timeslots=20arriving=20on=20the=20E1=20is=20slower=
=20than=20the=20speed=20the=20system=20takes=20them=20out,=20the=
=20E1=20framer=20device=20will=20create=20timeslots=20by=20duplica=
ting=20the=20last=20frames=20worth=20of=20timeslots.=20=20The=20de=
leting/creating=20timeslots=20during=20slips=20will=20be=20hardly=
=20noticeable=20to=20the=20human=20ear,=20but=20for=20data=20servi=
ces=20like=20fax,=20it=20will=20cause=20the=20kind=20of=20problems=
=20you=20are=20seeing.
=20
So,=20the=20solution=20to=20you=20problem=20is=20to=20get=20the=20=
system=20timing=20of=20the=20Audio=20codes=20box=20to=20be=20locke=
d=20to=20the=20E1=20clock=20rate.=20=20That=20may=20be=20difficult=
,=20if=20not=20impossible,=20given=20the=20features=20you=20descri=
be=20that=20are=20available=20in=20the=20Audiocode=20box.=20=20You=
=20indicate=20that=20you=20only=20have=20two=20choices=20for=20sys=
tem=20timing=20on=20the=20Audio=20codes=20box:=20=20Receive=20STM-=
1=20or=20external=20input.
=20
Since=20the=20STM-1=20clock=20is=20derived=20from=20Verizon=e2=80=
=99s=20network=20and=20the=20E1=20clock=20is=20from=20the=20DTAG=
=20network,=20you=20cannot=20use=20the=20STM-1=20clock=20because=
=20they=20are=20not=20locked=20to=20each=20other.=20
=20
Thus,=20you=20need=20to=20provide=20a=20clock=20on=20the=20externa=
l=20input=20that=20is=20locked=20to=20the=20DTAG=20timing=20someho=
w.=20=20You=20don=e2=80=99t=20have=20enough=20description=20to=20d=
etermine=20if=20that=20is=20a=20difficult=20thing=20to=20do=20or=
=20not.
=20
Finally,=20you=20can=20find=20a=20different=20receive=20device=20t=
hat=20allows=20the=20system=20timing=20to=20be=20locked=20to=20the=
=20receive=20E1=20clock.
=20
Good=20luck.
=20
Bill=20Matern
wtm=20at=20ncomm.com
On=20Mon=20Jan=209=2007:21:42=202012=20Ren=c3=a9=20H=c3=bcftlein=
=20=20wrote:
This Thread Bookmark this page:  YahooMyWeb Yahoo!  Google Google  Windows Live Favorites Windows Live  del.icio.us del.icio.us  digg digg  Add to Netscape Netscape
Subject Author Date
Different clock sources for STM-1 and E1 ?? René Hüftlein 01-09-12
Related PostsForumDate
Different clock sources for STM-1 and E1 ?? [telecom] General Telecommunications Forum 2012-01-13
How long time needed to get accurate frequency from SDH Telecom Technical 2012-03-24
System Clock Apparently Gaining One Second Every 30 Minu... General Telecommunications Forum 2011-07-09
Two computers, different download speeds. Wireless Networking 2011-02-03
self calibrating clock via wifi? General Home Automation 2011-03-31
How to set up Meridian 1 to "provide clock" to a Cisco IAD Nortel Networks 2010-08-24
Motion Detection Wall Clock Camera DVR Mini Clock camera DVR... CCTV, Alarms and other Physical Security 2009-11-04
gone independent, need sources CCTV, Alarms and other Physical Security 2009-12-27
Cell Phone Clock Inaccuracy [Telecom] General Telecommunications Forum 2009-01-22
Cell Phone Clock Inaccuracy [Telecom] General Telecommunications Forum 2009-01-16
Verizon: Apple's iPhone made us think different about mobile... General Telecommunications Forum 2010-07-25
ip phone clock sync with ntp ? Cisco Systems 2009-11-21
Napco clock drift CCTV, Alarms and other Physical Security 2008-11-12
Netgear - XE103 vs XET1001 - what's different Wireless Networking 2010-02-12
Latest PostsForumRSS
Can an intruder remotely reset a Linksys WRT54G v5 router to... Wireless Networking
Bob L. ( Message forwarded) CCTV, Alarms and other Physical Security
Mac to VLAN mapping on Cisco switches Cisco Systems
Sality virus help – how to get rid of w32 Sality.a e malware... Networking Firewalls
Verizon in $63 Billion Faceoff With AT&T Over Family Pla... General Telecommunications Forum
Question about SmartHome 1132CU programming General Home Automation
Toronto Free Cisco Seminar CCNA CCNP CCIE & BBQ Cisco Certification
SIP Proxy Server on Windows Vista?†Voice-Over-IP
WE ARE BUYING NETWORKING - TELECOM USED AND NEW EQUIPMENT CI... Ethernet LAN
Satellite or cable service for local TV broadcasts? Cable Modems
Modular UPS Telecom Technical
Verizon's DSL or not in my upcoming home area? Digital Subscriber Line
Water Damage & Fire Damage Sterling Heights Michigan Nortel Networks
About the Cat 7 cable LAN and Telecom Cabling
Fire Damage Clean Up & Smoke Damage Restoration Home Automation
VPN Soft Reset? Virtual Private Networks
FA: Joe Kane's VIDEO ESSENTIALS laserdisc Home Theater
Fiber Optics in Access Network_CFP Fiber Optics
Which Forum is best for professionals in the alarm business Electronic Security in UK
SIP SDK 3.6 Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Order Now for Instant Download
