66 Block wiring question
Threaded View
To save money at my church we recently went from 4 phone lines to
two.  The phone company simply disconected two mumbers from their
end.  Now we would like to connect each line we still have to the old
disconected line.  So the room that now has a disconected line will
share a line with the room next door that has a good line.
I found the 66 push down block,  with phone numbers listed on the
right (user) side for each of the lines.  How do I connect two lines
together (The now disconnected one with the still connected one)?
Thanks
Surf40
Re: 66 Block wiring question
Surf40 wrote:
Does the 66 block have silver clips stretching across the middle from
the left side to the right?
Take care,
Rich
God bless the USA
I reject your reality
and substitute my own.
                  -----Adam Savage
Yes,  and there are removable "bridges" that connect the middle two
columes of clips.
So on the left side is push down clips with wire from the phone co
box.  Down the middle are the two sets of clips with the bridges,  and
on the right are the other set of push down clips with wires going to
the phone jacks.
Surf40
That's exactly what those are called - bridge clips.
Now, are you wanting both working numbers to go to every location?  Or
is one the voice line and the other a fax, modem or 'private' line?
Take care,
Rich
God bless the USA
                  -----Adam Savage
We just want two phone jacks in two separate rooms to share the same
line.  Right not one room has a live line,  and the other is
disconnected.  I think all I have to do is connect the wire from the
dead line to the clip that has the live (working) line.  Do I put two
wires on one clip?
Surf40
back on.  Do not put two conductors on the same pin as it will not make
a good connection.
Take care,
Rich
God bless the USA
                  -----Adam Savage
Thanks Rich.  I did it last night and it worked great.  I pulled the
wires from the open line,  and put them under the clips on the bridge
of the working lines,  and replayed the bridge.
Thanks Again
Surf40
Great, glad it worked.  Glad I could help.
Take care,
Rich
God bless the USA
                  -----Adam Savage
Site Timeline
