Telecom Technical 2 voice lines in an cat5 env
Subject Author Date
2 voice lines in an cat5 env Coyote Cub 03-03-05
Posted by Coyote Cub on March 3, 2005, 5:16 am
Does the following work? I have two phones in room A. I run a cord
from Phone 1 and Phone 2 into a 2 line/1 line splitter. I then plug
the splitter into a RJ45 patch panel. Cat5 8 wire cables run from that
patch panel to a patch panel in Room B. I plug another 2 line/1 line
RJ45 splitter into the patch panel, then run normal phone cables from
the splitter to two phone outlets. Yes, I know there are better ways
to do this, but this seems cheap and I have the parts (making it very
cheap.)
Posted by Someone on March 2, 2005, 9:24 pm
Should work fine, but the 2-line splitters (RJ-11) I've seen are a loose fit
in a RJ-45.
Posted by Coyote Cub on March 3, 2005, 5:30 am
>in a RJ-45.
Thanks. Gives me a fighting chance at least.
Posted by Ian on March 3, 2005, 5:07 pm
fit
> >in a RJ-45.
Yep works fine, You can even buy such a splitter for cat5 as well as sharers
that let you put one phone and one data connection through one cable and
twin data that puts two data down the same cable.
Ian
Posted by Coyote Cub on March 3, 2005, 5:21 pm
On Thu, 3 Mar 2005 14:07:20 -0000, "Ian" <spam"AT"bathfordhill.co.uk>
>fit
>> >in a RJ-45.
What I can't find, though it seems to make sense to me, is a splitter
that turns the cat5/rj45 into two two voice lines/rj11. I suppose most
of the time this is done at the patch panel and I am making a
non-standard system.
Similar ThreadsPosted
2 voice lines in an cat5 env March 3, 2005, 5:16 am
How POS is sent via STM lines? March 28, 2006, 6:18 am
Tie Lines February 23, 2008, 4:28 pm
telephone lines April 26, 2007, 7:42 am
Crossed lines after splitter February 13, 2005, 6:32 am
F1 and F2 lines - Explanation of Terminology August 2, 2007, 9:09 pm
Making my own POTS lines September 8, 2007, 11:29 am
cellular backup for phone lines July 13, 2004, 11:47 pm
Multiple POTS lines vs. Fractional T1 January 26, 2006, 3:01 pm
Voice Traffic August 24, 2004, 10:27 pm
How To Test For Source of Low Volume on Phone Lines? October 2, 2004, 8:42 am
Fractional PRI: How do I get the data lines to serve internet to lan April 14, 2006, 4:10 pm
Can you connect 2 lines in the NIU together to make them the same line, as shown? September 9, 2006, 2:43 pm
AT&T Voice mail system August 7, 2005, 5:26 am
Voice Mail Recording December 7, 2005, 3:16 pm
