|On Sun, 07 Mar 2010 17:20:19 -0500, Dan Lanciani wrote: |........ |> For anyone who has the necessary unix-style machine on all the time and |> whose answering machine is reaching end-of-life I recommend this approach. |> If you have other functions that can be subsumed by Asterisk (e.g., alarm |> dialer) the payoff may be even higher, though at the cost of increased |> single-point-of-failure issues. | |Must use a lot more juice than a stand-alone answering machine?
I was careful to specify that this applied to someone who has the necessary unix-style machine on all the time. I would argue that the incremental "juice" used by running Asterisk (which is likely sleeping most of the time) is probably less than that used by any stand-alone answering machine. Of course, it does depend on what you are using for the FXO interface.
|***** Moderator's Note ***** | |Not compared to the cost of a new answering machine: PC's are much |more power-friendly these days, and there are now "PC Cubes" that have |no mechanical parts and whose power consumpsion may be less than that |of an answering machine. | |In any case, the versatility of the Asterisk software makes the |comparison problematic: take a PC one-generation-out-of-fashion, some |free-as-in-speech software, and some time, and you have a compined |voicemail, PBX, and emergency-alert system for zero cash outlay. That |difference covers a lot of electricity.
I should mention that the machine I use for Asterisk must be at least three generations out of fashion (I've lost track of how they count but it is 6+ years old and it wasn't cutting edge when I bought it) and it also acts as my DVR (which is was doing before I installed Asterisk) and does a few other home automation tasks.
Oh, one tip if you install Asterisk: take the time (and it isn't much time--the Wiki makes it sound more complicated than it is) to make the Asterisk server process run as some user other than root. There are really very few file it needs to write and it isn't even necessary to change the ownership of the config and sound files. I suggest this because the Asterisk code, while very useful, isn't super robust. You don't want to be the next victim of some SIP-delivered stack overflow root shell escape attack. Similar note if you install the Festival speech synthesizer. There is no reason at all for it to run as root though that is the default installation.
Dan Lanciani ddl@danlan.*com
