You didn't need to know the internal springs and levers. BUT, there were many controls on the typewriter you did need to know about; things that today's electronic printers do automatically. (Dot matrix printers carried a few of these features.)
For instance, when loading paper, you had to line it up correctly otherwise it would type slanted. There was a guide to check the alignment and a lever to free the paper so you could slide it about as needed.
You had _two_ roller levers--one kept the registration, useful for subscripts and superscripts and erasing, the other changed the registration, useful for realigning already typed paper.
You could advance the paper through by hand by turning the platen knob.
You could change the ribbon from upper to lower and no ribbon at all. At one time, ribbons came in black and red ink, now they have a correction strip instead of red. No ribbon was to cut a mimeograph stencil.
You could set the line advance for 1, 2, or 3 lines for a carriage return.
You had margin settings.
You had a tiny bar with rollers on it to hold the paper against the platen. This could be lifted out of the way.
You could release the carriage and move it horizontally to any position you wanted, including in-between letters.
Different typewriters had different settings and levels of sophistication in the mechanics. Newer typewriters had half spacing.
Now, as mentioned, today's word processors all of this stuff automatically in different ways.
***** Moderator's Note *****At the start of my career in the phone company, only top executives could publish memos with a justified right margin: producing them required specially-trained typists with access to 1/2 and 1/4 space enabled typewriters.
At the end of my career, the ultimate executive perk was the ability to have a hand-written memo circulated.
"All is vanity".
Bill Horne Temporary Moderator
