FCC 12-126
Basic Service Tier Encryption, MB Docket No. 11-169
Adopted: October 10, 2012 Released: October 12, 2012
I. INTRODUCTION
- With this Report and Order (Order), we amend our rules to allow cable operators to encrypt the basic service tier in all-digital cable systems if they comply with certain consumer-protection measures. As discussed below, this rule change will benefit consumers who can have their cable service activated and deactivated from a remote location. By allowing remote activation and deactivation, we expect our amended rules will result in benefits to both cable operators and consumers by significantly reducing the number of truck rolls associated with provisioning service and significantly reducing the need for subscribers to wait for service calls to activate or deactivate cable service. At the same time, we recognize that this rule change will adversely affect a small number of cable subscribers who currently view the digital basic service tier without using a set-top box or other equipment. If a cable operator decides to encrypt the digital basic tier, then these subscribers will need equipment to continue viewing the channels on this tier. To give those consumers time to resolve the incompatibility between consumer electronics equipment (such as digital television sets) and newly encrypted cable service, we require operators of cable systems that choose to encrypt the basic service tier to comply with certain consumer protection measures for a period of time. In addition, we note that this rule change may impact the ability of a small number of subscribers that use certain third-party equipment that is not CableCARD compatible to access channels on the basic service tier. To address this issue, we require the six largest incumbent cable operators to comply with additional requirements that are intended to ensure compatibility with certain third-party-provided equipment used to access the basic tier.
