This is an unusual question, so please bear with me.
Once of the readers has asked for help interfacing a "Local Battery/Local Magneto" PBX with the PSTN, and I'm trying to think "outside the cubicle", and come up with a solution that doesn't require spending a lot of money.
Here's the situation: there's a rustic vacation setting in VZ territory, where every cabin has an honest-to-god wall phone with a magneto crank on the side and a battery in it to power the microphone. Yes, pretty much every image of Ma & Pa Kettle applies.
The cabins are connected to a central cord board, which is, literally, the telephone exchange for every building on the property, and which _also_ has a magneto and batteries for the operator's headset: just imagine a 555 board with a magneto on the side (in fact, that used to be an option for 555 boards). The cabins signal the operator with the magneto, by cranking the handle when they want to talk to another cabin or the office, the restaurant, etc. The operator does the same for calls between the cabins (or restaurant, etc.), i.e., (s)he cranks the magneto on the switchboard to ring the phone at the destination phone. After a call is completed, one of the stations "rings off", i.e., cranks the magneto to activate the "drop" flag on the operator's console, so that the operator knows it's time to disconnect.
Now, you're probably wondering why anyone would use such a setup, but AFAIK this is a real place, and the equipment is really there and in use every day. The reader I'm trying to help says the owners feel strongly that the "crank" phones add a distinctive charm to the cabins and create an "old timey" atmosphere which is good for business, so they are determined to keep the existing equipment.
Ergo, I have these questions, and I'd like to hear from Central Office technicians and engineers.
- Are central office dial tone circuits capable of accepting ring signals from a magneto PBX? In other words, if the PBX in question is attached to a dial tone "trunk", and the operator cranks the magneto, is the CO capable of connecting the call to a Verizon operator? (I know this *can* be done, because I once accidentally cranked a magneto on a surplus field phone that was connected to a dial tone line, and an operator answered, but the question is if it is a regular feature of common central office equipment.)
- Are the CO's Verizon uses capable of supporting "Ring down" trunks? Assuming that an ordinary "PBX trunk", i.e., a dial tone line, can't work on a ring-down basis, could Verizon option a circuit pack so that it can be done? I'm thinking of "manual service" lines used by paraplegics and others who can't dial a call.
- Assuming that options 1 or 2 aren't available, what "work around" is available that would allow the 555 PBX to interface with the PSTN despite it's lack of DC supervision and the need to use ring-down signalling?
Thanks for your help.
