I believe that at least some of the AT&T phones are actually made by Vtech.
I would stay away from the 900Mhz phones for a few reasons. First, the only multi-line phones available in 900Mhz are notoriously unreliable. Second, eavesdropping on many 900Mhz phones, even modern ones, is trivial.
In the 2.4Ghz band you will in fact see some interference with 802.11b or g networks (and probably with 802.11n when it's available). How much depends on how efficient your phone is and how busy your network is. The Gigasets were actually pretty good this way, but the incredibly poor quality control on the later handsets made them almost worthless as has been mentioned earlier in this thread.
Another option is to use an 802.11a network -- which operates in the
5.8Ghz band -- if you want to use 2.4Ghz devices such as phones. However, 5.8Ghz is even more directional than 2.4GHz and if your house has lots of thick walls and complicated angles in its layout you may not get good results with an 11a network. Phones need so much less bandwidth they don't seem to care much.The 5.8Ghz phones are a nice solution if you have an interference problem with a 2.4GHz wireless network, which many people do. The real problem is that as far as I can tell, no vendor sells even a
2-line 5.8Ghz base station -- as compared to 2.4Ghz where 2 and even 4 line sets are common. If, like me, you live in a building with a door intercom that's delivered to you on a phone line, being limited to one line on your fancy expandable cordless phone can be a real pain.Avoid analog phones no matter what band they're operating in. It is just too easy (and too popular) to eavesdrop on them. Unfortunately, though the Gigasets were intentionally designed to be difficult to eavesdrop on most of the newer stuff isn't; if this is a concern for you I'm not quite sure what advice to give -- except to stay away from analog cordless phones (now showing up on the market even in 5.8Ghz!) even if you don't think it's a concern. Sigh.
Thor Lancelot Simon snipped-for-privacy@rek.tjls.com
"The inconsistency is startling, though admittedly, if consistency is to be abandoned or transcended, there is no problem." - Noam Chomsky
