That's a very bad assumption. It's the voice-menu touch-tone: press 1 if you are a personal acquaintance whose first name I would recognize; press 2 if you are calling me in regard to an existing business relationship such as a credit card or bank account; press 3 if you are a stranger trying to call me to advertise a product or service; press
4 if you are offering me a job; press 5 if you are a stranger trying to call for personal reasons such as you want to discuss something interesting I posted in a newsgroup; press 6 if we met in person but I don't yet know your name but I'd remember meeting you.) which I don't have and am seeking.Do you know what such a device would be called and which newsgroup would be appropriate for asking about such devices? It would be nice if that one device also included decoding of caller-ID, so that I can put up different touch-tone monus depending on whether the call provides caller-ID or not and if so then whether the call is from somebody whose number I already know, and if a number I already know then depending on the number: -- You have harassed me and I asked you to stop calling. But here you go calling me to harass me again. Your call will be reported to the police. -- Hi daddy. Phone is ringing now. If I'm here, I'll answer shortly. -- Hi Margaret. Nice to hear from you. If I'm here, I'll answer shortly.
I already have a modem, a SupraExpress 56. When the phone rings, the modem sends just the word RING on a line by itself, with a blank line between consecutive RINGs. I don't know of any way to make it detect caller-ID and report that.
I don't think a mere "card" would be of any use to me. It doesn't sound like anything I can connect up to a phone line and program/configure in any simple manner. But just in case I'm mistaken in rejecting your suggestion, please tell me how somebody would program the "card" to set up the various touch-tone menus? Is there a keypad on the "card" for entering configuration commands, and a LED or LCD display on the "card" for getting responses to verify what I'm doing?
I looked on that Web site, but didn't see any description of the Whozz Calling box nor any link to such information. The only mention was "using our Whozz Calling? family of multi-line hardware." with no link to info about the device. The text " Features simple viewing, logging, and networking of both incoming and outgoing Caller ID . Setup screen, search and find hardware routine, help screens, documentation, and source code included." appears to refer not to the box but to some software that wouldn't run on my Macintosh in any case, and there's no mention of either software or hardware providing any touch-tone menu.
I did a Google search for "Whozz Calling box" and found:
OK, that would be a slight improvement on my current TPC-supplied caller-ID box which stores only the last 25 caller-ID info and requires me to manually view each individual record and manually re-key the information into a text editor. But I see nothing about supporting touch-tone menus.
- See any DTMF digits dialed ON INBOUND CALLS! Use this to verify what mailbox was dialed along with the Caller ID number! I assume DTMF is the technical name/abbreviation for the tones used by "touch tone" dialing. In the absense of any outgoing message, there's no reason anyone would key in any DTMF tones after getting a connection, so by itself this is of no use here.
I really need something that will enforce a touch-tone (DTMF) menu, which anonymous or other unknown/suspicious callers must traverse before they will be allowed to ring my phone. I don't see any indication that Whozz will provide that capability. If there's no such device that handles both touch-tone menus and caller-ID decoding to pick which menu to use at the start, then I'd settle for a device that didn't have any caller-ID decoding at all, merely uses the same touch-tone menu for all callers, and rings my phone only if the caller passes a "Turing" test for establishing the person as a known friendly acquaintance or relative. (I currently get ten to twenty harassing calls per day, and maybe one or two non-harassing calls per month. I would like the touch-tone menu to filter out everything except those very few non-harassing calls.)
