>>>>Now here's a bonus question: Who invented the chadless process? Was it >>>>the
>>>>Bell System (via Western Electric and Teletype) or was it Klienschmidt >>>>or
>>>>some other company? (I don't know the answer but I'd like to know!) >>>>
>>> I don't have a definitive answer, but it must have been Teletype/Bell
>>> System, because Kleinschmidt made typing reperforators that used 7/8"
>>> tape and typed on the edge where there was no punching. The reason
>>> for chadless tape was to provide a surface to print on, with a typing
>>> reperforator.
>>> ***** Moderator's Note *****
>>> That brings back a memory: the Model 19 I learned on had a typing
>>> reperforator, the Model 14 IIRC, which used "chadless" tape and
>>> printed on the chads. It also had a type wheel very much like the one
>>> later used on the Model 32/33. It was very useful for making "Brag"
>>> tapes, which were sometimes played during radio contacts: if you
>>> realized you'd make a mistake in the tape, you could run it through
>>> the reader on the Model 19, up to the point of the mistake, and type a
>>> corretion, and then run the rest: the reperforator would produce a >>> correct copy.
>>> The hams at M.I.T. had to wind replacement ribbons themselves, because
>>> the reels used by TeleType cost too much.
>>> Trivia question: when first establishing contact, the stations would
>>> often send a series of "RY" characters repeatedly. Why?
>> We're going back into the mental archives here. As I recall, that
>> string was as close as you can get to equal numbers of marks and
>> spaces. So whatever the loop current was (maybe 20ma), RYRYRY, etc
>> would cause to current meter to register half of the always-on loop
>> current. I've forgotten the name of that big relay (bi-polar?) that we
>> all got from the old Bell System. If it was out of whack, you would
>> get something more or less than the10ma in my example. Of course, you
>> could do the same thing locally with your model 15 tape distributor. >>
>> If this is right, do I win a prize? :-)
>> Herb Stein
>> snipped-for-privacy@herbstein.com
>> Herb, you're very close. Yes, the sequence "RY" _is_ an alternating
>> stream of Mark/Space signals, i.e., a "101010101010101010101010 ..." >> pattern.
>> However, it wasn't used to measure current.
> I've thought about this all day. And it is the pattern above, but
> you're ignoring the start and stop bits. But it is as close to your
> pattern as is possible. I'm going back to 1961 or so my memory
> fades. I can't remember if I have socks on! I don't remember what it
> measured, but I had a small meter which would be at about half the
> normal reading when the famous RYRY... was sent from the model 14 TD
> on the local loop. I guess I "misremember" what the meter was reading. >
> I still have the home-brew thing with the polar relay ans associated
> socket, H-88 Bell load coils, etc. I gave away the hardware years ago. >
> In any event, great flashback!
>> Bill Horne
>> Temporary Moderator
>> P.S. The prize is too incredible to mention!
> Herb Stein
> Herb, you're the closest, so you win. You're right: I didn't count the
> If you had a current meter in the loop and watched it during an RY
> sequence, I understand how it would show about half scale. I don't
> think that would be a good tuning indicator, though.
> In radio, the RY sequence was used to produce a "cross" pattern on a
> monitoring scope, or to guide a discrimator output meter to the
> center.
I never had that kind of fancy hardware, but I can see that working.
Trivia question #2: what is the equivalent character pattern when > using a Model 35?
> Trivia question #3: what key combination would produce a
> blank tape, with only feed holes punched, on a Model 33ASR?
I never had anything new enough to use the 8-level ASCII tape. Just the WWII surplus 5-level Baudot stuff. The old stuff was free from the Military Affiliate Radio System (MARS).
Being 15 in 1961, I had no contacts in the phone company to get the new stuff from.
Bill Horne
> Temporary Moderator
-- Herb Stein snipped-for-privacy@herbstein.com
Truth be told, I never had that kind of fancy hardware, either: my first TU was a two-tube unit that I tuned by watching the copy! I had a model 15 TeleType, which I'd bought for about $40, from a service which redistributed them to hams on a "Not For Resale" basis. It had a pin-feed platten, and so I was always scronging pin-feed paper. I would still have it today, except that my father put it in the trash while I was in Vietnam.
My first experience with ASCII was with the PDP-8 "Edusystem" computer used in local schools, which had a 33 ASR as a terminal. I got a job maintaining the TeleTypes, and they sent me to North Wacker Drive in Chicago to learn how.
That was during the time I was laid off from NET&T, so I didn't have any contact in the phone company, either, but if it's any comfort, they were still using Model 28's well into the Seventies: the first contact many of their own repairmen had with ASCII was in fixing the Model 35's that came with the 1A ESS, and they'd still use "RY" as a test pattern, even though "U*" was the equivalent ASCII sequence.
Bill Horne Temporary Moderator
