I keep getting calls from 800-706-0971. Its listed on my caller ID several time a day every day during the week.
Thanks.
[TELECOM Digest Editor's Note: You might try using *60 to 'block calls from last number received, although I am not sure that would absolutely end the calls. I've tried dialing 800-706-0971 at various times since I first received your message; it is always busy. I do not think it would help to use *60 to block 800-706-0971 since that number is just a bogus entry on your caller ID anyway. Better to block 'last call I received, whether or not I know the number', which will oblige telco to at least attempt internally to figure out the calling number although they (telco) will not tell you the number in any event. PAT]
