We have an old AT&T Partner Plus system at work. We have 3 incoming lines and about 12 extensions.
Some of the extensions ports have developed some static on them.
I understand how to program the Partner System and change or add extensions as needed.
We would like to upgrade to a system that has voicemail.
Should I look at getting a newer partner system with voicemail? I see alot of used/refurbished Partner Systems available.
How good is the voicemail on newer Partner systems? A local installer told me that in his opinion the Partner Systems were never really meant to have voicemail. I think he meant that Partners are older technology and voicemail was an add on and not part of the original design of the system.
