DSC British Gas Home Security system
I recently bought a flat which had a British Gas security system fitted already. My guess is that this is about 3 y old. The whole system seems to be complete with wireless sensors in every room and one device attached to the door. Having read through previous listings i can see that it is usually a re-branded DSC that BG use, and that BG don't give out the master codes for installation. In fact on the inside of the LCD control paned there is a discreet 'DSC' in the corner.
Installing a security system that will only sound if there is a problem (ie without necessarily linking up to a monitoring centre) will keep the wife happy. As I want to save in paying for a complete new system I was wandering if anyone could let me know if I can make use (or part use) of the existing hardware.
For instance is there a way of me finding out the master code for this system without subsidising BG's already over inflated profits?
Or, if ripped out their LCD control panel and replaced it with a new DSC one, would it work with the rest of the hardware?
Many thanks and happy holidays,
Stef.
