I have on several occasions attempted to explain these things to you. All that happens is that you end up not understanding what's going on and through your ignorance you end up ranting. A week or so later you post again saying that no-one has explained these things to you. If you have such a problem understanding wireless systems why don't you contact a manufacturer directly?.
If you really want to learn about wireless technology in alarm systems why don't you ask a proper question here on this newsgroup. You never know, someone might educate you. I haven't given up hope yet but I must admit that when you constantly post lies on top of lies it doesn't help. You are not subjective.
I can explain how. If you ask me I will tell you how it works. You only have to ask... nicely!.
In all my time reading your posts I cannot remember seeing any technical supported arguments with reference to RFI jamming detection. Show me some. And in reference to the above, I will give you whatever technical arguments you want. Don't rant. Just ask.
Just so that I know, what type of 'smoke curtains' are you talking about. Please give me an example.
Bad english here but I think what you're after is How is a high level of background RFI detected. Is this what you are getting at?. If so all you need to do is contact a manufacturer & they'll probably tell you. I can tell you if you like. Just ask. It's actually very simple so maybie you could understand it.
Older systems maybie. Newer systems... ah! smell the roses. RFI jamming detection in all its glory. Want to know how it works?. Ask away.
