My Moose Z1100 is telling me that I need a new battery. What is the procedure for changing it? Is it as simple as disconnecting the old and re-connecting the new?
Thanks,
--Jeff Z.
Thanks,
--Jeff Z.
Ya and give it 12 hours and test it
what is it a 12V 4 AH or a 7 HA
Best to ask about RED and BLACK leads first :-) It's a capacity rating... 4AH means it'll deliver 4 amps (current) for an hour or 8A for half an hour or 2A for 2 hours, catch my drift?
Aww mikey you spoiled all the fun
I'm replacing a 7AH battery with a 7.5.
as long as it fits in the case and it has the same voltage as the last one, the bigger, the better
You can..no problem...it'll give you a little more backup time.
I've done it. It's fun with an alarm panel maybe but not 2G paging system :-(
OK, I switched batteries last night. No alarms, no police. ( I was just a little worried that disconnecting the battery might trip the alarm.) Thanks, guys.
Next up, I need to change batteries in my flashlight. It it as simple as taking out the old batteries and putting in the new ones???
Just make sure the little buttons on the top of the batteries face one another. Also you can save some money if you only change one battery at a time.
Yes, it's that simple. Regardless which battery you have in there now, replace it with a 7- or 8-Amp Hour model. They're only a few dollars more than a 4 AH unit and they last much longer during a power failure.
Regards, Robert L Bass
