All Ademco's have cabinets except for the Lynx.
The Ademco wireless wall mounted keypad doesn't have much of a range.
Alternative would be a wired keypad and maybe a keyfob arming/panic device you could keep in the MBR..or carry around the house.
Seeing as though your neighbors did nothing on this last break-in, why would you not have it monitored?
Alarm systems only speak alarm language, you or your neighbor probably won't understand what it's saying. You'd have to add a voice dialer to any alarm system to do what you want (Im not recommending this, just telling you that youd have to buy another thing).
| >> Hi, | >>
| >> I need a security system and have been looking at the Ademco LNXRPK, | >> Visionx PowerMax, Napco P3200 and DSC PC5020. | >>
| >> The house is two stories about 1800 sqft with about 20 windows. I | >> figured that two motion alarms with wireless entrance alarms for the | >> two downstairs entrances would cover most of the house. | >> Also I would like to have a smoke alarm and a wireless remote siren. | >>
| >> I'm not going to have the system monitored at this point, but will | >> have it call me or my neighbors when an alarm gets detected. | >>
| >> Any of the above mentioned systems standout better than the others? | >>
| >> Is there another system I should look at? | >>
| >> Thanks in advance! | >>
| >> Dave | >>
| > Scroll up a little and have a look at the thread about "DIY | > recommendations requested". | >
| > Frank Olson | >
| | Frank, | | i saw the thread, but it didn't address my needs. | From What I've seen only Ademco has a wireless keypad, but it doesn't | have a cabinet for the CPU. | I'm new at this, just had my house burglerized this week and looking for | a solution. | I need pretty much wireless everything. No basement or availablity to | the attic for wiring. The mounting of the CPU and keypad in different | sides of the house. | | I wish I had more flexability for more of a hybrid system. | | If I was in a single story or had a basement, i'd be in high cotton. | | Dave |
