I'm looking for a wireless security receiver for commercial buildings that can handle several motion detectors as well as door and window contacts. The ideal receiver should also have dry contact outputs for every sensor in order to connect them to any commercial alarm system. I'm looking for a receiver that is not designed for a particular alarm panel, but one with a generic output that can work on several different systems from different companies.
So far I found one from Inovonics that seems to meet those requirements. They have relay outputs for every sensor.
Thank you for your suggestions, J-S Lauzon
