Don't take too long to change the batteries, or you have to reprogram the transmitters. Jeeez.
js
js
I only did a handful of the 2020 panels...worked great but programming was a pita, and then building the translation tables for the CS setup was a real pain...so did not continue with their panels but did use their receivers and xmtrs with other systems...still do.
I know that other ( I use Napco) mfg's have wireless keypads but in my experience they are usually tempermental, very slow to function and the batteries have to be changed more often than you'd like. The most annoying thing about them is how long they take to send and receive commands. You want to leave and you've got to stand there after you've armed the system for it to send the command to the system and then receive the confirmation that the command has been received and implimented. Much too long to have to wait for most people.
Napco does have a remote two way keyfob that has a darn good range on it. At least a hundred feet and most times more. It confirms that the command has been rec'd and implimented with both a visual and audio response. The only thing that is NOT good about any Keyfob remote is the lack of a security code.
If it were me, I'd wire it ...... no matter what it took to do it.
Most times I talk my clients out of keyfobs and only provied it if they ask for it and insist on it.
I ran into that, the first one I did... turned out I was wrong. Just push the transmitter reset button.
If you say so. I don't remember seeing a reset button. Those brain cells are long gone.
Its sounding like the wireless solution has more problems than soltutions so Im thinking that just use the exsting sensors and wiring and add a wired panel. The current system has a key thats mounted on the main box thats about 6' off of the ground. Short people has trouble reaching it is the reason for adding a panel.
I see that Ademco is not very popular so how 'bout some recommendations for a good panel thats easy to program.
Thanks for the discussions!!!!!
A glass keypad? Cool...them's expensive.
That's the problem with untrained back door guys.
Whaddya got...maybe I'd trade my box of DSC pulls with you?
reset is tiny...I think it's near the terminals iirc.
Ademco is cheap but solid stuff and easy to program (relatively)
I don't have the massive storage space of Jim Rojas, so I left the stuff there in a box. I think it'a an XR40 (?) and 3 of them fancy-Dan keypads.
He, just didn't see it I guess. I'll have to put on my specs next time.
Damn. I'd take it...send you 100 lbs of DSC for it.
The 40's a nice box. The glass keypads are EXpensive!
Technically yes, in reality they are junk and not worth it.
5828 and 5828V
Yea thats from Secure Wireless, they also make one for DSC, Honeywell has a better one called the 5878, you can configure pairs of buttons to disarm instead of one
I always liked the 5804BDV, big but well built with voice
My rule of thumb is never trust v1 of anything DSC makes, this is from experience with their original wireless system (WL900), original sensors, original PC5010 v1, NT9010 Envoy v1.... I think they realize this since all the new panels started at v4.1
Also don't forget the RF receiver that under certain conditions would ruin itself and the panel, not v1 but you get why people are a little skittish
I have to go back out there to add some stuff next week. If it's still there, I'll grab it up.
Yeah that receiver bummed me out too, but it was fixable. Not defending DSC necessarily, as they have had their share of warts.
cool lemme know
