The 411 dialer fire lite sells is a knock off of the radionics dialers was wondering will the pro 411 programmer work on those older radionics dialer or do you need something else.
- posted
12 years ago
Like the programming software???
If you are referring to the D2071, you will need a D5200. The Pro 411 uses a 16-pin ribbon cable to connect to the 411 DACT. While the D5200 uses a 4-pin connector to connect to the D2071.
thanks
