Hi:
I am pre-wiring my new house under construction. I have a 76lbs greyhound that will be moving in with my wife and myself. I am preparing to run the
4/22 shielded wire for the 8 motion detectors. Each bedroom will have one motion detector. My Living room / Dinning room / Kitchen (open floor plan) will have 2 detectors with a ceiling that starts at 8 feet and goes up to 10 feet. Every detector's corner has an 8 foot ceilings. The alarm system has yet to be determined, but all the sensors will be hard wired.Will my dog likely set off the pet friendly detectors if I mount them up high in the corners? Or, do I have to mount them down low, 3-1/2 to 4 feet, to create a "pet ally"?
Is there a particular model detector that would work well up high in the corners?
Can I leave the detectors up high and put a mask in them to restrict their lower detection?
What do you think?
Thanks, John
