I am a novice to alarm systems. But had ADT install a smart secure pro 3000 in my house. I understand this to be a Ademco Vista 20P.
My problem is that last week some repair guys came and replaced a door in my house. While I was away, they removed the sensor and moved it to the new door.
since then, the keypad has reported "check zone 12". I've tried entering my code plus "off" 2x as per the manual to reset zones. It doesn't work. I've tried moving the sensor around while my wife keys in the reset codes.
I tested the battery with a multimeter and it's fully charged. At this point, I just don't know what else to do.
Can you advise me please?
Thanks
