System Sensor 2W-B
System Sensor 2W-B
Is this smoke detector any good? I want to use it on my Ademco Vista
  1. Or should I go with a 4-wire?
Injun Ear
It is an excellent smoke detector.
Jim Rojas
Jim Rojas
I hope so, I use a lot of them.
alarman
Me too...when I can't get Hochikis
Crash Gordon
Its a very good unit. You are better off with a two wire smoke. With a four wire you need to install a power supervision relay module to do it right. RW
Roger W
Like others have said, good unit.
Remember though: Only one zone can be used for 2-wire smokes (Z1) so plan your wiring accordingly.
G. Morgan
If he home runs 4c to each smoke, he can take care of the planning in the panel. In/out, In/out, etc. Service advantages, too.
Steven Vaughan
If you are going to be using these in a residential setting I recommend that you go with the 2WTA-B.
The 2W-B does not have a sounder in it. In a residential fire you want as much noise as you can get.
JoeRaisin
I like the 2WTA-W (thermostat and sounder).
alarman
"alarman" wrote in news:Fmutl.83906$RJ7.82256 @newsfe18.iad:
I do too. if it's not a wireless install, chances are that it will be a 2wb or 4wb.
motley me
I use the thermos too...have a buddy that swears by the sounder option too...I've only used the sounder ones where I've needed them though.
Crash Gordon
I use them with a reversing relay (# RRS-MOD I think.) It triggers sounders on all smokes if any one trips.
alarman
dat be's code to have sounders in bedrooms, eh?
KingFish
The 2W-B (2 wire) does not show up on the compatibility list for the Vista 20. You'll have to use the 4W and an EOL supervision relay. Only the following 2-wire smokes are compatible (see page 18 of your Vista 20 installation manual):
System Sensor 2300TB, 2400, 2400TH, 2451 w/ B401B Base, 2451TH w/ B401B Base, 1400, 1451 w B401B Base, 2451 w/ DH400 Base, 1451 w/ DH400 Base,
1100 and 2100T
Use only UL approved compatible devices for connection to a listed panel. And the pro's here should really check their facts before opening their big yaps! :-)
Frank Olson
thought they did that automajickly?
Crash Gordon
RockyTSquirrel
Indeed. dat be's.
alarman
Donno, never tried it without the relay. The smokes are designed to sound off if the polarity is reversed.
alarman
