I installed a Scantronic 500r+ wireless control panel + PIR's probably 15 t o 20 years ago. I have a AG6 external bell + strobe unit hard wired. The system has worked reliably since day one then about a month ago the bel l + strobe unit started making more frequent cheeping noises (like very lou d magpies). I tried to solve the problem by trying various tests but finall y figured out that the AG6 tamper switch had become faulty. I bought a repl acement Honeywell AG6 from Amazon and installed - easy, until 2 days later the Scantronic control panel has stated making a low droning noise from the loudspeaker. There is no 'fault' registered in the system but I have had t o temporarily disable the whole system by opening the control panel door. It seems too much like a coincidence that I replace the Ag6 bell + strobe a nd very soon after the control unit speaker starts acting up - as if its pi cking up a feedback signal from somewhere. I've tried Cooper Scantronic but you need to get past the registered instal ler code system ........ I would appreciate any suggestions. Many thanks
Ian MacKenzie
