Hi Folks
I needed to replace a couple of mains sockets yesterday and switched off the power so I could work safely. The power was off for about 30 mins.
When I went to bed last night I set the alarm but it triggered as I went past the PIR on the staircase (which should be omitted when the alarm is part set). My access code wasn't recognised and there followed a bit of a panic as I dug out the user manual to try and work out what was wrong.
I tried the default master code and this stopped the alarm - all this suggests to me that the battery in the alarm is no good and the alarm system has lost its programming when I had the power off.
I've tried to find the installation/engineer manual to the Pargaon Plus panel on the web, but have learned that these documents tend not to be made public. However, from searching old usenet posts I've found what the default engineer code is. I think the only thing I need to do now is program the panel to omit the upstairs PIR when part set.
Can anyone help me with some instructions on how to do this??
I called Pyronix, who made the panel, to see if they would let me have the info. But they are closed for the weekend. If there is someone here who could help with needed info then it would be much appreciated.
TIA
