Easy pal, it's hard to diagnose a problem with even simple electronic systems without hands on it and doing things to test it that actually come out of your subconscious. I mean things you've done for so many years, that you do them without thinking. I'll play a hunch on gear that's broken because I've seen so many failures of the same type or similar equipment for many years. I often find problems using just my eyes and my nose. I use a small flashlight or my lighted magnifying glass to look to look for cracks or loose components on a circuit board. I often do a wiggle test on vertically mounted components like the filter capacitors to check for broken solder joints on a circuit board then I often twist the board when it's powered up to check it for bad or intermittent connections. It's often a big mistake to assume another fellow has done tests that I would do without thinking about it. ^_^
TDD
